A couple of questions
Old Dec 29, 2008 | 07:46 PM
Rover Curious's Avatar
Default A couple of questions
OK, so I'm poking around under my hood today, trying to familiarize myself with all the various stuff under there. There's a small canister on the passenger side near the firewall that has what appears to be a small air filter inside of it. What is this? I can only assume it's some sort of cabin air filter, but I don't know. Also, in the cab, on the dash to the left of the steering column, there is a flat black filler plate that sticks out from the dash a little bit. Upon removal, there is a rectangular opening, and a slightly recessed round opening. What is this? I can't even begin to guess what this is for.
Also, mounted to the firewall, there is some type of button that has a rubber cover over it. Any ideas?
Old Dec 29, 2008 | 07:51 PM
ryanD2's Avatar
Default RE: A couple of questions
Sencondary air injection pump under the hood is my best guess, ive pulled the cover of mine and cleaned. its a little foam filter. and the other from what i gather is just an option plate, maybe where the SLS button would be. or something the previous owner had installed.
Old Dec 29, 2008 | 07:54 PM
Yes the first is your secondary air.
The second sounds like a blank, a spot open for other factory buttons.
Old Dec 29, 2008 | 08:14 PM
I didn't think about the secondary air. My other vehicles with it have not had their own secondary filter. I figured the plate was for a factory option, I just wondered which one. I think I've figured out through RAVE that it is for headlamp leveling. Weird thing is, it seems like the mechanism is there, it's just not hooked up. ?
Durfee
May 7, 2006 11:02 PM
thairs
Apr 13, 2006 05:50 PM
AndrewBone
Aug 4, 2005 01:17 AM
UNCRover
May 10, 2005 02:45 PM
Bene
Freelander
May 10, 2005 01:41 AM
