a couple of questions... ugh..
Well, I have two question.
The first one was, that when I am driving on the highway, (speeds of 55 or more) whenever I press on the accelerator, I hear a high pitched noise. As I get faster, the noise gets higher; but it is only when I am pressing the accelerator.. ?? Any thoughts??
And the second thing is, I've noticed that after I've been driving a while, and I stop at a red light, the rear suspension "relaxes" alittle. I only notice it if I am looking through the rear view mirror, and then I litterally see the back go down. Is that normal?? I notice it with just me in the truck, as well as when I have passengers.
Thanks!! I appreciate all the input!
John-Robert
John-Robert
RE: a couple of questions... ugh..
Both of you need to inspect you drive shafts. I had a u-joint going out and it made the same noise. But, Rovers have a gear driven X-fer case, so some whine is normal. If your front driveshaft does not have grease fittings, have it rebuilt immediately. If it goes, it will slap the tranny out.
bootzilla
10-11-2012 01:13 PM
Snafu / Disco Fries
12-07-2011 06:30 PM
