a couple of questions... ugh..
Old Apr 25, 2007 | 05:01 AM
johnnybob06's Avatar
Default a couple of questions... ugh..
Well, I have two question.
The first one was, that when I am driving on the highway, (speeds of 55 or more) whenever I press on the accelerator, I hear a high pitched noise. As I get faster, the noise gets higher; but it is only when I am pressing the accelerator.. ?? Any thoughts??
And the second thing is, I've noticed that after I've been driving a while, and I stop at a red light, the rear suspension "relaxes" alittle. I only notice it if I am looking through the rear view mirror, and then I litterally see the back go down. Is that normal?? I notice it with just me in the truck, as well as when I have passengers.
Thanks!! I appreciate all the input!
John-Robert
Old May 3, 2007 | 12:13 AM
ZMayo85's Avatar
Default RE: a couple of questions... ugh..
I have a '02 Disco SE and notice the high pitched humming, it comes and goes but its nottoo loud and only really happens at high speeds
Old May 3, 2007 | 01:49 AM
okdiscoguy's Avatar
Both of you need to inspect you drive shafts. I had a u-joint going out and it made the same noise. But, Rovers have a gear driven X-fer case, so some whine is normal. If your front driveshaft does not have grease fittings, have it rebuilt immediately. If it goes, it will slap the tranny out.
Old May 3, 2007 | 01:54 AM
ZMayo85's Avatar
thanks for the info i'll have it checked out, I caught a rock in the windshield today soIhave to get some repairs anyways :-(
Old May 3, 2007 | 02:00 AM
ZMayo85's Avatar
Another thing I've noticed some is when I turn really sharp like into a parking space my brakes become quite hard to press with a little bit of a grinding noise, it doesn't seem normal. Has anyone heard of this happening?
Old May 3, 2007 | 10:00 AM
Rondo's Avatar
Not sure what to say about your brakes, but the whine when pressing the accelerator sounds like a smallleak in the intake or vacuum system.
Old May 3, 2007 | 12:06 PM
Do you do any of your own mechanical work, if so I would be glad to walk you thru a few of these issues.
Mike
bootzilla
Oct 11, 2012 01:13 PM
outdoor7or24
May 21, 2012 08:34 AM
Snafu / Disco Fries
Dec 7, 2011 06:30 PM
GARovee
Apr 14, 2010 08:34 PM
Michael1
ROAMING WITH FRIENDS
Jun 17, 2006 01:12 AM
