Cracked Block Check?
Old May 4, 2010 | 10:37 PM
audiS4S6's Avatar
Default Cracked Block Check?
So, I got antsy before my leak down tester arrived and I pulled one of the heads ( the other one has a stripped bolt - see my other thread).
Anyway, where do these blocks crack?
Is the crack obvious?
I figure I would check the block over while the heads are getting done (once I get the other one off).
She was puking oil out the valve cover but maybe elsewhere too.
Thanks for all the help folks. I will be able to provide some good insight after my Disco is up and running - take the load of you guys a bit.
Old May 5, 2010 | 06:25 AM
Rovin4life's Avatar
take pictures and send it to a dealer to get his opinion. but the only sure fire way to know about a cracked block is to literally seal the water jackets off and every coolant hose and pressure test from there.
Old May 5, 2010 | 07:03 AM
Isn't there also a chemical treatment you can use to locate block cracks?
Old May 5, 2010 | 08:14 AM
audiS4S6's Avatar
I could do a die penetrant check but I won't be able to get to all areas with it installed.
I do not see any cracks, I just though if they do crack in a particular place, I could have a look-see at my block...
Old May 5, 2010 | 10:42 AM
greg409's Avatar
The only one I've seen (video) was at the edge of the sleeve, just out side the top of the liner. http://www.google.com/url?sa=t&sourc...047ogsmftzC82g
Get out you're popcorn. LOL
maybe this will help.
luck,greg
Old May 6, 2010 | 06:23 AM
audiS4S6's Avatar
luck,greg
WOW! That is an interesting video. What's scary is that they developed a tool (kit) to find cracked blocks. Must mean it is common.
Old May 6, 2010 | 08:41 AM
Antmen's Avatar
Yeah, I'm sure if there wasn't a market for it, they wouldn't have developed the product. Ouch.
-Anthony
Old May 6, 2010 | 02:09 PM
audiS4S6's Avatar
-Anthony
$250 seems like a lot for what it is. I will make my own. At least I will be able to lend out to others on the forum. You should only need it once or twice in your lifetime.
rewi9d
Apr 27, 2020 05:46 PM
DiscoArt
Nov 11, 2009 03:30 PM
twmj1953
Jun 21, 2009 03:52 PM
unstable
May 28, 2009 10:25 AM
37chambers
Oct 28, 2005 09:03 PM
