Crank case position sensor questions
Old Oct 16, 2015 | 01:13 PM
ukwildcats's Avatar
Default Crank case position sensor questions
Just replaced my sensor - was having issues with stalling and no start which I could not find a cause except for CPS failure, so went ahead and replaced.
Questions
1. Is there supposed to be a gasket between the CPS and mounting surface - if yes what is the part number.
2. I did not reuse the mounting bracket, am I asking for a problem. Did not see a reason to use, and with order vehicles using CPS have never seen a bracket.
Installed the CPS and it did start (would not start before the sensor replacement)
UK
Issues I was having
- stalling sometimes at stop lights/signs
- intermittent no starts
- and on "ultra gauge", sometimes I get and error, especiallyallythe engine temp reading
How I replaced
- did not touch the exhaust
- removed heat cover from below
- remove sensor from below
- removed bracket from below
- used a metal cloths hanger to pull sensor up to driver side of engine
- removed bracket by pushing on on tab
- disconnected CPS connection from wire harness (from to side)
- reconnected new CPS from the top side
- should of put bracket back on from to side but did not
- allowed CPS to fall back down
- reinstalled
Far easier to do than the first time I replaced 6 months ago - but really wish wire from vehicle was longer
Old Oct 16, 2015 | 02:03 PM
Toran's Avatar
Did you reinstall those little silver spacers before the sensor?
You really need those!
Old Oct 16, 2015 | 02:13 PM
ukwildcats's Avatar
Yes i reused the spacers - and installed those after sensor was put on - then the nuts.
I got the CPS at advance auto parts - which does not come with a gasket.
UK
Old Oct 16, 2015 | 02:16 PM
Toran's Avatar
Yep!
That sounds about right, I think I need to get another one from the same place.
I'm right across the bridge from ya
Woody Reems
Jul 14, 2009 08:30 AM
oljohnboy
Mar 30, 2009 08:54 PM
wosmo
Aug 7, 2008 11:24 PM
DiscoOn22s
Apr 19, 2008 05:12 PM
lacruiser
Feb 28, 2008 07:24 AM
