crank sensor
Old Nov 26, 2008 | 01:16 PM
stupid's Avatar
Default crank sensor
i cant get the crank sensor unplugged. im not skinny enough to reach it. can someone help?
Old Nov 26, 2008 | 03:59 PM
jkid's Avatar
Default RE: crank sensor
Sure, bring it on over! Or a couple of flat screwdrivers, long needle-nose pliers and some patience should do it. If you can use the screwdriver from aboveto pop the connection out of it's holder andI think you can reachit a lot easier.
Old Nov 27, 2008 | 09:04 AM
stupid's Avatar
i tried that and it worked got long screw driver and moved it over the holder . now how do you pop it back in?
Old Nov 27, 2008 | 10:05 AM
jkid's Avatar
Yeah, getting it back in the holder is the hard part. I had to try about 10 different body and arm positions before I could get in the right position, damn wrists just don't want to bend the right way. Be creative, you'll get it. You might be able to pop it in with the screwdriver.
KlamathMatt
Apr 17, 2020 05:27 AM
cgeschwell
Feb 23, 2011 01:01 PM
Wildwolf498
Nov 27, 2008 01:22 PM
stupid
Nov 23, 2008 01:17 PM
discomel
Apr 30, 2006 06:28 PM
