crank sensor / fuel pump
So after talking to mike earlier (thanks by the way) ive narrowed my starting problems down to two possible culprits... ive already bought the crank sensor and plan on installing it tomorrow. My question is this... for replacing a fuel pump on an 04 disco, which years will work with mine and since I have sai do I have to buy a fuel pump that works with it?
The electrical connector end, yes. Access is tight in that space, made for Martians with long skinny fingers. Be sure every spacer and washer and nut goes back in the same spot, alignment is critical. Here's a page on it.
BTW, getting at the fuel pressure test port on the rear corner is not an easy task (as compared to the the "out-where-you-can-get-at-it" on the D1).
Travelor
09-24-2015 06:11 PM
gschmitt
12-14-2014 05:06 PM
JumPeR04
04-07-2011 09:52 PM
