crank sensor / fuel pump
Old Oct 1, 2012 | 11:56 PM
shady milkman's Avatar
Default crank sensor / fuel pump
So after talking to mike earlier (thanks by the way) ive narrowed my starting problems down to two possible culprits... ive already bought the crank sensor and plan on installing it tomorrow. My question is this... for replacing a fuel pump on an 04 disco, which years will work with mine and since I have sai do I have to buy a fuel pump that works with it?
Old Oct 2, 2012 | 12:08 AM
For the CKP sensor, plug it in and let it dangle to install. If still no-go, would consider used or after market fuel pump (replaces some of the internals of your existing one).
Old Oct 2, 2012 | 12:19 AM
Which end are you talking about plugging in? The plastic snap end? Not being smart but whats the reason to do that?
Old Oct 2, 2012 | 12:45 AM
jfall's Avatar
Unless you have over 150,000 miles - then I doubt your fuel pump is failed.
Fuel pumps fail after a certain number of running hours.
Seems around 180,000 miles fuel pumps are failing.
Old Oct 2, 2012 | 05:38 AM
drowssap's Avatar
check you fuel preasure at the rail, hours and milage have nothing to do with when you fuel pump will give out.
Old Oct 2, 2012 | 05:50 AM
The electrical connector end, yes. Access is tight in that space, made for Martians with long skinny fingers. Be sure every spacer and washer and nut goes back in the same spot, alignment is critical. Here's a page on it.
BTW, getting at the fuel pressure test port on the rear corner is not an easy task (as compared to the the "out-where-you-can-get-at-it" on the D1).
File Type: pdf
Travelor
Sep 24, 2015 06:11 PM
gschmitt
Dec 14, 2014 05:06 PM
JumPeR04
Apr 7, 2011 09:52 PM
cgeschwell
Feb 23, 2011 01:01 PM
stupid
Nov 23, 2008 01:17 PM
