Crower 229 cam in 4.0?
Old Feb 10, 2015 | 06:30 AM
ImQuattro's Avatar
Default Crower 229 cam in 4.0?
Ok, so I learned something the other day.
The 4.0 cam is different from the 4.6 cam.
I wasn't aware of that as I was under the knowledge that the differences were only in the lower rotating assembly.
During my latest rebuild on my neighbors '02 Disco 4.0 I had purchased and installed the same Crower 229 cam that I had used in my 4.6.
Will this have caused any problems?
Old Feb 10, 2015 | 08:08 AM
It shouldn't cause any issues, as long as it was installed properly.
Old Feb 10, 2015 | 08:26 AM
dusty1's Avatar
Good for either.
Crower only machines the end to make a different fit from Buick 215/300/340 to rv8. Doesn't matter if it's 3.9/4.0/4.6
It fits, it works. Just a short nose, lobes are same
Just make sure to do the first start up, 10-12 miles from civilization.
Old Feb 10, 2015 | 08:35 AM
ImQuattro's Avatar
It was already installed. we've just been trying to track down a noise in the motor. I've ben through everything and shot of a major teardown I'm baffled.
It sounds like a bad lifter. Lifters are new and with the lower intake and valve covers off, they are all operating perfectly.
The cam looks like new and all the lifters are spinning as they ride the ramps.
When I read the profiles are different between the 4.0 and 4.6 I thought that maybe the new cam's lift was too much for the 4.0 setup.
Old Feb 10, 2015 | 08:42 AM
jafir's Avatar
People put "stock" 4.6 cams in 4.0 for "performance" so it shouldn't be an issue. I'm not sure of the gains, if any.
Old Feb 10, 2015 | 02:30 PM
acamato's Avatar
You are OK. I have a 229 installed in my 4.0. No issues.
ImQuattro
Jan 19, 2024 02:54 PM
ImQuattro
Sep 18, 2014 09:35 PM
ImQuattro
Mar 26, 2014 11:58 AM
ImQuattro
Mar 17, 2014 08:10 PM
BCDisco2Lando
Aug 7, 2013 10:19 AM
