Cruise control vacuum pipes?
Old Jun 16, 2017 | 08:38 PM
Patrick Duffy's Avatar
Default Cruise control vacuum pipes?
Hi - i have LH Drive V8. On the passenger side is the cruise control unit. There are 2 vacuum pipe spigots on the underside, one white and one black. Just one rotten piece of tube remained. I can find nothing going back to any point. I do have one vacuum tube coming of the brake servo which is continuous - no T points or joints. That runs to the top of the engine to draw vacuum pressure.
What do I need to run new tubing to please?
Old Jun 16, 2017 | 10:08 PM
dgi 07's Avatar
I'll post a picture in the morning if this doesn't help
Old Jun 17, 2017 | 06:36 AM
mollusc's Avatar
The cruise control unit is its own vacuum pump, so it doesn't need any connection to the engine vacuum.
As the diagram above shows, there should be two pipes associated with the unit: one loops around from the bottom where the vacuum is drawn to another port further up the unit, and the other goes to the bellows that pulls on the second throttle cable.
Old Jun 17, 2017 | 01:58 PM
Default Thank you!
I have the Rave manual but there was nothing showing the tube layout. From other posts they referenced a tube back to the brake pedal with a T Piece in it and there is nothing like that there.
I will get this done in the next week and report back! Just then got to get the aircon charged and the windscreen washer system feed replaced! And then there is repairing the ABS, again! Took the back seats out for room for camping with the dogs - up to Glacier Nat Park in August whilst there are still glaciers there!
Old Jun 17, 2017 | 02:02 PM
mollusc's Avatar
You don't say the year of your D2, but my '99 does not have any vacuum lines going anywhere other than what I describe, and the cruise control works fine. I believe that the vacuum dump function formerly handled by the line to the brake pedal is now handled electronically.
From memory, there is a flanged port on the bottom of the cruise control unit that does NOT have a vacuum line on it -- it's a breather port.
Old Jun 18, 2017 | 08:15 AM
mln01's Avatar
That's correct, no DII uses engine vacuum for cruise control.
The who's that failed on mine is the one that, as mollusk says, runs from the back of the bellows that pulls on the second throttle cable. It loops up and then down and then loops again underneath the unit to attach as shown in my pictures.
Two other short hoses, one from each of the white and black ports on the bottom of the unit, run to other ports next to the electrical connector, again as pictured.
Attached Thumbnails Cruise control vacuum pipes?-photo377.jpg   Cruise control vacuum pipes?-photo437.jpg   Cruise control vacuum pipes?-photo619.jpg
Old Jun 18, 2017 | 10:42 AM
Default Thanks again for the replies!
Those photos really useful. I will get some hose today and hopefully it will be fixed.
Old Jan 27, 2019 | 09:24 AM
The_OGCJR's Avatar
Old post bump...Patrick, did you ever get yours fixed? I bumped this thread because the other threads on this incorrectly talk about a vacuum line from the brake pedal...which doesn't exist.
I have same problems except my vacuum lines on the pump are not damaged.
Old Jan 27, 2019 | 10:28 AM
Dave03S's Avatar
P38's have the brake pedal vacuum line. Not sure why the confusion. However that is a different design with the bellows over by the master cylinder on the drivers side (LHD.)
Old May 12, 2020 | 09:52 PM
Kdscott10's Avatar
thanks. So we are looking at three hoses? I found the looping hose to be broken so now I will have to replace the other short hoses so cover off vacuum problems. Thanks
robert.juric
May 29, 2019 03:10 AM
attworth
Sep 12, 2018 06:45 AM
clint70
Feb 11, 2016 11:37 AM
Gerard
Mar 14, 2011 11:07 AM
ghostrider747
Feb 24, 2009 07:02 AM
