Cv joint replacement
Old Feb 20, 2022 | 04:42 PM
merebel's Avatar
Default Cv joint replacement
Ok one is clicking, this weekend didn’t help it 😁. So how hard is it to remove the cv joint from the axle shaft?
and while I am there
replace seals
ball joints ??
and should I do both cv joints ?
Old Feb 21, 2022 | 04:20 AM
frostythor's Avatar
That depends on weather you replace it a a full unit or replace just the CV joint, as full unit will probably need the gear oil draining, but if you keep the drive shaft in and can remove the CV not as messy, but you still need to remove the hub and brake disc, caliper and it a lot cheaper to do just the CV it self
Old Feb 21, 2022 | 05:01 PM
merebel's Avatar
Ok and how about getting the cv joint off the axle shaft?
Old Feb 21, 2022 | 06:01 PM
The Deputy's Avatar
It knocks right off with brass hammer, hold axle shaft and hammer it off.
Remove wheel center hub cap, and then remove axle nut while wheel is on the ground. Much easier, unless you have impact.
Old Feb 22, 2022 | 04:32 PM
merebel's Avatar
OK so I found this kit
https://rimmerbros.com/Item--i-RD1260BP
And should I also do my ball joints too? I dont think they have ever been done and has 175k on it
Old Feb 23, 2022 | 02:11 AM
frostythor's Avatar
Hi a Bearmach kit is £31, but the having bought from them in the past they guarantee every item for 3 years, I have had stuff thats failed not a lot I may add just the odd item ,and they have replaced it with out a problem or refunded the cost of the item
Old Feb 23, 2022 | 06:30 AM
keninnc's Avatar
Removing the axel is not as difficult as it seems. Putting it back in is surprisingly easy. You would think it would be difficult to line up the splines but my experience is has been relative easy.
Ball joints are another story. Unless you are sure they are shot I suggest not replacing them or consider hiring someone to do them. That is a much bigger job.
Old Feb 23, 2022 | 08:12 AM
merebel's Avatar
I figured since I am there. also the hubs are about 3-4 years old and the rest has been all updated so after cv joints the only thing left will be ball joints lol
jrm123180
Mar 8, 2020 12:33 PM
austinlandroverbill
Feb 16, 2017 07:57 AM
austinlandroverbill
Feb 12, 2017 10:19 PM
stephenspann27
Feb 12, 2015 04:52 PM
buick215
Dec 5, 2012 12:57 AM
