Cylinder 4 Misfire
Old Dec 10, 2010 | 08:49 AM
michaelblythe33's Avatar
Default please help po306
Hello when i got this 2000 discover 2 it ran fine after a few weeks i noticed a slit hesitation it got worse over time now i have no power and it sounds like a moped which i be leave is a miss when im on interstate i can feel it running ruff then its doing a catch up thing you can feel it run trig to run perfect witch it does fo 2 sec then goes back to crap no power kinda like a clogged fuel filter which i guess is not severs able my code po306 heres what ive done new plugs/4 o2s /beat out cad converters which i will replace win car runs right they were bad and it was stopping me from finding my prob i need a friend to help me threw this so i dont have to spend any more money then i have to my converters are going to cost 500 i guess and i already spent 500 on parts just want to find the prob
Old Dec 10, 2010 | 07:37 PM
Fairview's Avatar
Default Noticed the same thing
Originally Posted by lordmorpheus
...and thank you for reporting back!! So many people have problems, post their symptoms on the forum, do some troubleshooting, then talk to Mike on the phone. Once the problem is fixed, nothing more is reported. If another member is having the same problem, they will probably read through the thread looking for a solution, only to find the only apparent solution is to call Mike, and the process continues ad infinitum.
Yes, I noticed the exact tendency- like hearing the joke but without the punch line. I tried to start a thread "Code Library- with answers" a day or two ago, but no takers so far.
https://landroverforums.com/forum/sh...ad.php?t=36381
Old Nov 20, 2020 | 08:37 PM
Roverdisc's Avatar
4th Gear
Default Cylinder 4 missfire.
Originally Posted by Disco Mike
Factory plug wires are some of the worst in the market, if you want help tracking this down, PM me your number and I'll call and walk you thru what to do.
Hi Disco Mike. I have a cylinder 4 misfire on a 2004 disco 2. I am at my wits end. I have switched out plug wires. The plugs are new. Also switched coil packs. Checked injector pulse no issue there. Installed a new injector for cylinder 4 also. Getting strong spark to the plug. Truck starts and rung great. Idles like a rock. Runs fine unless you get over about 2500 rpm or under heavy load then check engine light blinks and throws cylinder 4 misfire. Throttle position sensor appears to be working by looking at the live data. The only thing I can think of that could be causing this issue is either the ECM or possibly the cam position sensor. I would think that if it were the CPS I would be getting a random misfire not just cylinder 4. Do you have any ideas on this?
scarrell
Nov 16, 2012 06:04 PM
louianquin
Freelander
Jun 9, 2008 03:18 AM
rover
Freelander
Apr 28, 2008 08:42 PM
xb70valkarye
Oct 23, 2007 12:50 PM
lajilana
Sep 2, 2006 10:47 AM
