D II squeezng noice on seconda air pump
Old Apr 28, 2019 | 04:26 PM
tonydliu's Avatar
Default D II squeezng noice on seconda air pump
Hi
My 2003 D2, when start, there is the squeezing noise coming from the secondary air pump, after a ~1min, the noise is gone. It appeared to be normal
Should I replace the secondary air pump? Didn't find anyone reporting or replace the secondary air pump.
Thanks
Tony
Old Apr 29, 2019 | 12:36 AM
Lisa Bunch's Avatar
Mine does it on start up, and sometimes idling at a traffic light. You can remove the end and clean the foam filter. It sounds like a little jet engine, kinda cool.
Old Apr 29, 2019 | 03:41 PM
tonydliu's Avatar
Lisa, Thank you. I'll give it a try. Any tips as how to open and clean?
Old Apr 30, 2019 | 01:47 AM
JUKE179r's Avatar
There is a black cover that pops off and contains the foam filter. The filter will be very brittle so be careful when trying to clean it.
Or do like I did and install a removable and cleanable K&N 1" air filter part # 62-1370...
Frtpilot
Oct 31, 2018 03:55 AM
Lando
Oct 30, 2018 06:39 PM
mark d
Jun 21, 2013 05:13 PM
charcoal grey
Mar 2, 2009 11:22 PM
ClayinSA
Jun 28, 2008 03:55 PM
