Noise on Start Up
Old Jun 28, 2008 | 01:39 PM
ClayinSA's Avatar
8th Gear
Default Noise on Start Up
I have a '01' Disco that when starting from cold has begunto give a 1 minute or so whailing noise. It sounds like a fan/air box noise coming from the firewall-passenger side area. It goes away after a minute or so and doesn't make this noise when engine is warm, isn't really affected by throttle either.
ideas?
thanks, clay
Old Jun 28, 2008 | 02:14 PM
jdelp's Avatar
Default RE: Noise on Start Up
That would be your secondary air pump taking a dive. If you're not getting any fault codes, it may be salvagable...at least for a while. I've posted on a quick resolution for this before, do a search for secondary air. basically just remove the in and out hoses from both your secondary air pump and vacuum pump while cold, spray some WD-40 or other lubricant in there, reconnect hoses and start it up. I've also removed the filter from the secondary air pump and sprayed in there while it's running...will quiet it down quite a bit.
Old Jun 28, 2008 | 03:55 PM
ClayinSA's Avatar
8th Gear
no error codes...other than the three amigos of HDC, AL, & TC which I begin tomiss after they haven't come for a few days...;-)
thanks for the suggestions...will try this evening as ithasn't moved today.
clay
david4ducati
Mar 1, 2015 07:59 PM
30more
May 28, 2012 05:01 PM
armyeng
Mar 8, 2011 05:58 PM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
