D1 Door Handles
Old Jul 1, 2009 | 09:31 AM
kenk's Avatar
Default D1 Door Handles
I want to replace my outer drivers door handle, works fine but bottom hinge is broke so you cant just grab and open. According to rave cd you have to remove the glass,regulator,lock mechanism,etc..
Has anyone done this? Does all that need to be removed? And lastly, can the lock cyl be switched over so I can use the same key?
Old Jul 1, 2009 | 11:15 AM
SDinDS's Avatar
You only have to remove the glass, regulator, etc if you are replacing the latch.(lots of fun!!) You can remove the handle by accessing it from inside the door. Don't know about swapping the lock cyl... I just used the key mine came with (bought it used)
Eric
Old Jul 1, 2018 | 01:23 PM
Jerry DeCamp's Avatar
Disconnected the linkages from the inside of the drivers door handle and took out the 1 Torx screw. Can't figure out what else is holding the handle in. Don't want too force it. Any ideas?
Old Jul 1, 2018 | 01:52 PM
Just had to pry it a little harder to get it out! Bent the sheet metal a little bit, bent it back flat and installed handle.
cornercase
Apr 26, 2022 08:17 AM
Rover_Hokie
Aug 19, 2014 10:05 PM
ToddD
Jun 24, 2012 09:14 AM
hh65flyer
Dec 18, 2011 10:18 AM
'BamaBoy
Jun 2, 2010 09:38 PM
