D1 front brakes replacement
Old Mar 14, 2007 | 06:24 PM
handsome rob's Avatar
Default D1 front brakes replacement
Doing the brakes for the first time on my 94' D1. Is there a writeup? or anything out of the ordinary that I should look out for? Any suggestions is greatly appreciated.
Old Mar 14, 2007 | 08:37 PM
98roverguy's Avatar
Default RE: D1 front brakes replacement
Replace the disks with the pads. (if you didn't already know)
Old Mar 14, 2007 | 09:31 PM
Where are you getting your pads from, how about rotors.
Most Rover outlets sell a kit with everything you need including the seals.
Make sure you repack your wheel bearings, make sure the ABS sensors are pressed in all the way,and bleed the brakes.
Mike
Old Mar 15, 2007 | 12:53 PM
I have not decided where to get the parts from yet. Which Rover outlets do you reccomend? I know to do the discs and pads at the same time, but I didnt think about packing wheel bearings then also so thanks for the tip.
Old Mar 15, 2007 | 08:09 PM
98roverguy's Avatar
This kit sold by our own geoman has all you need. They are the right pads and rotors that wont squeal or cause problems. I will be buying from him when I need to do mine... http://www.eurotekapg.com/catalog/it...71/3065579.htm
FightOnUSC79
Nov 26, 2010 09:43 AM
lipadj46
Jul 21, 2009 01:51 AM
BadAssHog
Mar 19, 2008 10:50 PM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
