D1 front brakes replacement
Doing the brakes for the first time on my 94' D1. Is there a writeup? or anything out of the ordinary that I should look out for? Any suggestions is greatly appreciated.
Where are you getting your pads from, how about rotors.
Most Rover outlets sell a kit with everything you need including the seals.
Make sure you repack your wheel bearings, make sure the ABS sensors are pressed in all the way,and bleed the brakes.
Mike
Mike
I have not decided where to get the parts from yet. Which Rover outlets do you reccomend? I know to do the discs and pads at the same time, but I didnt think about packing wheel bearings then also so thanks for the tip.
This kit sold by our own geoman has all you need. They are the right pads and rotors that wont squeal or cause problems. I will be buying from him when I need to do mine... http://www.eurotekapg.com/catalog/it...71/3065579.htm
lipadj46
Jul 21, 2009 01:51 AM
