D2 front driveshaft replacement
Old Oct 11, 2018 | 09:13 AM
Ben Matheson's Avatar
Default D2 front driveshaft replacement
I see a special tool sold by lucky8 and AB. Is it necessary? Just looks like an extension
Old Oct 11, 2018 | 09:19 AM
tcr6v1's Avatar
9/16th wrench, a few extensions and a ratchet and you'll be good. I find it easiest to put the front end on jack stands, and jack up one side of the rear axle so the wheel is off the ground. Lay under the truck and use your foot to spin one of the front tires and you'll be able to get the driveshaft to turn making accessing the other nuts a little easier.
Old Oct 11, 2018 | 09:24 AM
LR03NJ's Avatar
Not really but you need 2 similar sizes
Old Oct 11, 2018 | 09:49 AM
I have an electric impact gun so that should help
Old Oct 11, 2018 | 10:27 AM
Sixpack577's Avatar
You won't be able to get a socket on the bolts at the angle they go in at. You'll have to use a wrench.
Old Oct 11, 2018 | 10:48 AM
Big Jim Swade's Avatar
I see Lucky 8 has their front drive shafts down to $188 at the ebay store. Is there any negatives to their drive shaft?
Old Oct 11, 2018 | 11:32 AM
That's the one I got but I called them direct to save them the eBay fees. They have been great to work with.
landroverdude
Oct 5, 2019 07:45 AM
Brandon318
Apr 8, 2019 10:04 AM
aemnky606
Dec 8, 2018 04:45 PM
Rover144
Mar 20, 2015 11:58 AM
NiteTrain
Aug 26, 2008 02:04 PM
