D2 front driveshafts rebuild
Old Mar 23, 2015 | 07:16 PM
OffroadFrance's Avatar
Default D2 front driveshafts rebuild
I've seen a lot recently on front D2 driveshafts (propshafts in the UK) so I thought I post this for rebuilding guidance.
www.discovery2.co.uk / Workshop :- front and Rear propshaft
Old Mar 24, 2015 | 06:04 AM
drowssap's Avatar
maybe a mod will move with the other how to's
Old Mar 24, 2015 | 09:11 AM
dusty1's Avatar
now someone tell me how to change out the spindle and spring that is captured by the centering ball
Old Mar 24, 2015 | 09:51 AM
Have you got a photo you can post Dusty. I've done 2 now and both have been .......... eeerrr .............. problematical. (problem is when word gets around you've done one someone turns up with theirs who's gotten into the sh!te cos they started reassembling it wrong)
Isn't the pin with the spring fitted inside 'fixed' into the shaft end trunnion? as I'm not sure it comes apart as a separate item. What exactly is wrong with the pin is it mullered? or just worn?
The pin looks to be welded in or maybe heat sweated into place (I can see some blueing around it on the article photo). If you remove the outer ball rubber seal you can maybe get a closer look at how it's fixed in. I believe the seal is 'glued' onto the trunnion so go careful 'cos I've never seen them as a separate item for sale yet.
Old Mar 24, 2015 | 09:59 AM
dusty1's Avatar
Yes....I was halfway joking, as I didn't even think it was possible It does look like it's welded on there. The problem is I don't have any idea how to find a replacement to weld on there. I guess I can take it to a driveline shop.
Old Mar 24, 2015 | 10:07 AM
dusty1's Avatar
Done....
Old Mar 24, 2015 | 05:11 PM
You're a bigger wind up merchant than me I think if the pin was worn you'd need to have one made and hardened or case hardened (it probably has a small flange) and either MIG or TIG it onto the trunnion after the old one was ground off. How you'd get it square and centralised F.K's, I'll watch you do it first though
Old Mar 24, 2015 | 07:46 PM
antichrist's Avatar
Done....
Was already.linked in this post:
https://landroverforums.com/forum/ge...02/#post164811
Old Mar 24, 2015 | 07:53 PM
dusty1's Avatar
ooops
done twice...will fix thank you
Old Mar 24, 2015 | 09:54 PM
jfall's Avatar
Take the drive shaft to a drive line shop.
Let them repair it.
Make sure they spin and balance it.
dusty1
Mar 28, 2015 02:46 PM
fishEH
Aug 22, 2012 08:46 AM
VikingDiesel
Oct 26, 2009 10:50 PM
mrcrptguy
Jan 21, 2009 11:27 AM
danelsis
Dec 6, 2007 01:25 PM
