D2 Glove Box Wood Trim
You do not need to remove the airbag. I just put a wood trim on my 2000. After you remove the glove box. There is a piece of foam glued to a metal support that you need to pry loose and remove, then you can get to the nuts. I also put wood on the doors. That was pretty easy too. The locations for the holes are already in the foam on the back side of the door panal. Just drill thru with about a 1/16 drill. Then drill thru the other side with 1/4" drill.
Willie
Willie
APSIS USA
04-30-2008 10:52 AM
