D2 Mystery noise
Old Jul 12, 2017 | 09:03 PM
HBW1020's Avatar
Default D2 Mystery noise
So about two weeks ago this horrid chirping/squealing noise arose. First it was quiet, then it got louder and louder and louder. Then it disappeared. It sounds like its coming from the underbelly close to the front of the car. And it only chirps while the car is under load (when i'm moving and accelerating) The mystery noise was gone for about a week then it came back worse than ever. At first I thought it could be a driveshaft issue but typically driveshafts make a clunking noise when the U joint is shot.
Check out the video below. I know its damn near impossible to diagnose a car from a sound and description so i'm not expecting much help, so instead I was wondering if anyone had some tips or tricks for locating the noise.
Old Jul 12, 2017 | 09:21 PM
LR03NJ's Avatar
https://www.youtube.com/watch?v=1Z2dYuGvaG8
still could be your front drive shaft. Just raise both front tires go under and turn wheels to check your shaft is tight.
Old Jul 12, 2017 | 09:54 PM
HBW1020's Avatar
What other bearings are involved with the front drive shaft?
Old Jul 12, 2017 | 10:21 PM
LR03NJ's Avatar
Usually the u joints had to be checked due to premature wear and also the double cardon which contains the bearings. Check if there are grease fittings between the U joints and grease them. It would be better to raise the truck so you can physically check them while turning the tire.
Old Jul 13, 2017 | 04:49 AM
HBW1020's Avatar
Update: So I removed my front driveshaft to take it for a spin and the chirping noise is gone! Not suprised.. I have the 04' model so I am able to lock the center diff and drive off. I understand that all of the power that originally was going to all four wheels is now going to two but I was wondering how dangerous that could be. With light acceleration I should be okay for at least a couple of days, right? Is it the highway speeds or the acceleration that puts stress on the rear axle?
Old Jul 13, 2017 | 04:52 AM
HBW1020's Avatar
Thought i'd upload a picture of the culprit. Broken bearing.
Old Jul 13, 2017 | 06:42 AM
mln01's Avatar
You'll be fine. You now have just an old-fashioned rear wheel drive truck.
BTW, when I upgraded my driveshaft years ago I bought the U-joints and the centering ball and had a local driveline shop do the work. But the price of good quality, fully greasable driveshafts has come down in recent years and I now wouldn't bother doing what I did. Just buy a new one and install it. But make sure all three U-joints are greasable.
aaron22
Jul 4, 2015 09:15 PM
twaszak
Feb 5, 2013 12:15 AM
chrisusvi
Feb 12, 2007 11:32 AM
alex of minnesota
Dec 21, 2006 09:40 AM
meyersd
Oct 9, 2006 09:21 PM
