D2 ran out of gas. Can't keep running. Please help
Old 11-15-2019 | 10:18 PM
Bodeanjt's Avatar
Originally Posted by Friday Night Disco
I apologize as I read that now in original post. Could you have pulled some gunk that is now clogging injection. Is there any codes present or pending?
No worries. I don't have a code reader and I live too far from a parts store to be able to drive to get code pulled. I don't think the check engine light is on when It is running.
Old 11-16-2019 | 09:22 AM
Red5's Avatar
Originally Posted by Bodeanjt
Just stops like you shut off the engine
That sounds more like an spark issue. Have you ever replaced your CPS? Maybe that was the original issue, you just happened to be low on fuel when it let go.
I replaced mine proactively so I haven't seen it personally, but some report symptoms just like you are seeing. Once it heats up a bit, a connection fails. After it cools down, metal moves just a bit and it works again. Then repeat.
Bodeanjt (11-16-2019)
Old 11-16-2019 | 10:13 AM
Bodeanjt's Avatar
Thanks buddy I will give that a try.
Old 11-30-2019 | 02:02 PM
Bodeanjt's Avatar
I replaced the CPS and now she's running great! Thanks for the help!
JUKE179r (11-30-2019)
Old 12-02-2019 | 07:24 AM
Red5's Avatar
Good news, thanks for the update.
Dylan Webster
04-29-2019 12:59 PM
toofaroffroad
Range Rover Classic (1st Gen)
12-07-2018 07:53 AM
laselvasurf
07-25-2017 10:15 PM
Sarahcake
03-02-2016 10:24 PM
j.dstasio
09-11-2015 07:28 PM
Quick Reply: D2 ran out of gas. Can't keep running. Please help
