D2 shuts off, restarts if batt disconnected for 15 min. p0447, P1514 & p1551
Old Dec 23, 2023 | 02:11 PM
Armando's Avatar
Default D2 shuts off, restarts if batt disconnected for 15 min. p0447, P1514 & p1551
Hi everyone. I'm stumped. My D2 will shut off after a while. If I disconnect the battery for 15 minutes, it starts but dies again in the same way.
I did clean out the idle air control valve with throttle body cleaner. The problem did not go away.
Has anyone had this problem? Any suggestions? Thanks in advance.
Old Dec 23, 2023 | 02:38 PM
Armando's Avatar
Additional info, I disconnected the IACV and it ran rough for almost 5 minutes and then did the same thing.
Old Dec 24, 2023 | 04:27 PM
Harvlr's Avatar
Crank Position Sensor?
Old Dec 24, 2023 | 04:49 PM
Armando's Avatar
Thanks! I kept searching after this post and spoke with a friend. It seems like CPS is the culprit. Unfortunately, it will be a few days until it arrives.
I removed, cleaned, and reinstalled it in hopes that it would work until the part arrives. It ran much longer than before but eventually shut off.
Old Dec 27, 2023 | 02:51 PM
Armando's Avatar
It appears you were right. I changed it and the car has been on for 25 minutes now.
Old Dec 27, 2023 | 03:46 PM
Harvlr's Avatar
Great news!
Rover_Hokie
Nov 26, 2016 02:53 PM
JohnKimble
Sep 17, 2013 12:13 AM
TElam
Dec 28, 2012 01:30 PM
alwaldin
Defender
Oct 11, 2007 10:53 PM
theRange
Sep 7, 2007 03:55 PM
