D2 sunroof leak help
Old Sep 20, 2024 | 12:46 PM
nashvegas's Avatar
Everything here is true but one huge piece is missing:
These leak between the plastic sunroof frame (that goes in from above the car, not below) and the metal roof of the car. The upper plastic frame is only held on by adhesive tape that has gaps, and that adhesive bond has usually perished by now in 2024. You need to remove the upper plastic frame (by dropping the lower metal frame) and remove it, clean it, and sikaflex under it to seal.
3 leak points on these:
1) Between roof and plastic sunroof exterior frame
2) Rubber seal under glass lets too much water into tray
3) The drain nozzles break off and the plastic drain trays come unbonded from the metal lower sunroof tray.
#1 cannot be ignored -- it is a huge leak failure point.
Old Oct 11, 2024 | 03:07 AM
Alexx111's Avatar
4th Gear
Originally Posted by Alexx111
I was going to use 3/8 brass hose fittings i stead plastic nipple but it looks like there is some.mechanism inside.how come people screwing the brass. It wont even go half an inch.
any thought on this?
Old Oct 11, 2024 | 09:03 AM
Extinct's Avatar
Yes, either cut down the end of the brass nipple or don't thread it in farther than that.
DiscoTanB
May 23, 2018 11:13 AM
zeroone
Jun 1, 2014 09:26 PM
Juergen33911
Jun 19, 2013 12:49 PM
kenk
Jun 26, 2012 09:59 AM
noahsfortune
Feb 5, 2010 08:21 PM
