D2 swap back to air ride
Old May 29, 2017 | 11:53 AM
Best4x4's Avatar
I've got an aluminum panel on my D2's rear cargo door. Since I don't have the Subwoofer installed I'm thinking of doing a custom air pump install.
I can route 12v super easy to the door, and I plan on installing the pump on the backside of the panel with rubber bushings to keep the vibration down, then redo the wiring and put an On/Off switch on the aluminum panel, and then have an airline quick disconnect installed on the aluminum panel so I can quickly install/remove one of those 50ft coil air line hoses. It would be out of the way and a nicely custom install.
The ARB pump or something similar should be able to fit in the space inside the door.
Although I removed SLS from my 99 D2 I kept all the hardware.
Old May 29, 2017 | 04:18 PM
Mskembo's Avatar
That sounds like a great setup! I'm probably just going to put an airpump on the passenger side firewall.
Old May 30, 2017 | 10:05 AM
Luckyjayb's Avatar
Where did you find the air pump rebuild kit?
Old May 30, 2017 | 11:48 AM
OffroadFrance's Avatar
Most aftermarket dealers sell them but try here:
https://www.google.fr/search?q=disco...+seals&start=0
Be very careful which way up you fit the piston ring or you'll end up with zero compression. XR8 seem to do a good download and vid.
00 Disco II
Jul 26, 2017 09:41 PM
Rfactor
Nov 30, 2007 07:38 AM
LandRoverDiscoDos
Apr 7, 2007 04:49 PM
mr mike
Jan 7, 2007 05:37 PM
mr mike
Jan 7, 2007 02:54 PM
