D2 v8 no power to engine fuse f1 or fuse f2
Old Nov 19, 2024 | 05:21 AM
Kurgan's Avatar
Exclamation D2 v8 no power to engine fuse f1 or fuse f2
Can anyone please help? 1998 4.0 THOR No power to engine fuses F1 & F2, car will crank but no fuel pump, or spark, it also has a 400mA parasitic draw. Need to get this car up and running again as wife wants to burn it.
Old Nov 19, 2024 | 09:02 AM
mollusc's Avatar
Did you try pressing the inertia switch on the firewall to reset it?
Old Nov 19, 2024 | 03:45 PM
Kurgan's Avatar
Yes, it was replaced during engine swap carried out last year.
Old Nov 19, 2024 | 03:55 PM
mollusc's Avatar
Ok, you replaced it. Did you reset it afterwards?
Old Nov 19, 2024 | 05:54 PM
Kurgan's Avatar
Yes, because the car was running, battery went flat and now won't start. Found out it's now got no power.
Quick question. If a BCM has been unplugged then plugged back in. Do you need to get Nanocom to relearn security codes?
09dewaed
Feb 18, 2018 07:49 AM
colemtd
Nov 18, 2016 04:48 PM
Beaulim
Sep 26, 2015 09:27 AM
Pet
Aug 2, 2014 09:55 PM
