Dash instrument / climate / radio lights flickering
Old Oct 14, 2020 | 10:25 AM
Bumble's Avatar
Default Dash instrument / climate / radio lights flickering
Climate, clock, radio, speedo backlights, all in sync. I think I've got a bad connection somewhere, likely having to do with the brightness dial to the left of the steering wheel. Has anyone encountered this before, and is it an easy fix? I figured this would be a common thing, but my searches haven't turned up anything.
It doesn't appear to be battery related - just random dimming / brightening. I can really make it dance if I fiddle with that horizontal wheel.
Old Oct 14, 2020 | 03:31 PM
Llamasayswhat's Avatar
It is probably a bad light dimmer switch(the horizontal **** you are talking about) or the connection is poor. I would pull the cluster binnacle off - CAREFULLY- the plastic is very fragile and check the connection at the back of that switch. If the connection is good, start with a new one
bballjames
Dec 3, 2012 03:43 PM
photocrimes
Feb 20, 2011 08:05 PM
carlitonsky
May 27, 2009 10:12 AM
Rover601
Jan 28, 2009 07:39 AM
domyo
Aug 27, 2008 06:26 PM
