dash lights
Old Oct 10, 2015 | 09:48 AM
Mr R's Avatar
8th Gear
Default dash lights
Hi all. Just got 51 plate Discovery Td5 auto. Two problems - first is that neither Sport or Manual mode lights come on (not even at ignition) so the mode switch by the gear lever does nothing - secondly I believe the LCD display is supposed to display the selected gear (mine doesn't). Are these two faults connected or totally separate, and anyone got any ideas on how to fix??? Any advice appreciated, Thanks
Old Oct 10, 2015 | 04:45 PM
Twix's Avatar
Check the shifter linkage. There should be a plug or two there. They should send their information to the cluster via the computers. That's where I'd start.
Old Oct 12, 2015 | 05:59 AM
Mr R's Avatar
8th Gear
Thanks for the reply, does that involve stripping down the gear selector or is it something that can be done from underneath the car? Don't really know where I'm looking!!
Old Oct 14, 2015 | 10:27 AM
jafir's Avatar
Any recent work done to this, or did it just happen on its' own?
I'd be looking at BCU or XYZ.
Old Oct 16, 2015 | 05:54 AM
Mr R's Avatar
8th Gear
No recent work done to my knowledge, just never worked since I've had the car
Old Oct 16, 2015 | 04:32 PM
Twix's Avatar
You should be able to lift the black plastic around the shifter and see if that button is plugged in, the selector switch should be with the actual linkage just below that black plastic trim around the shifter
booper169
Mar 20, 2019 09:37 PM
gatorgrizz27
Aug 2, 2011 04:11 PM
snowdude
May 23, 2010 10:20 PM
Doral300sc
Feb 6, 2010 03:59 PM
tonyzp007
Jan 26, 2007 11:21 PM
