Dash switches
Old Apr 27, 2013 | 11:25 PM
Tomzsix's Avatar
Default Dash switches
Are the switches on the discovery dash a "plug and play"? I mean that when you remove the "blank switch" , can you put in an operating switch for lets say" front fog lights", will that work? Are all wiring harnesses pretty much the same?
Old Apr 28, 2013 | 12:15 AM
ZGPhoto's Avatar
Old Apr 28, 2013 | 03:03 AM
ScreamingLife's Avatar
Originally Posted by ZGPhoto
Okay, that response literally made me laugh out loud.
Old Apr 28, 2013 | 07:35 AM
To answer your question, yes you can add a new Rover switch, it will not be plug and play cause you will need to wire up to a power scource at the engine fuse block and add a relay and wire assembly down to the lights you are wanting to ad, it is not hard.
Old Apr 28, 2013 | 08:12 AM
And the wiring harness, with connector pins and color diagrams, is part of the RAVE (circuits manual and electrical library). Sometimes you will find extra connectors just waiting to be used. But if adding wiring, be sure to fuse it. Roasting Rovers is not fun.
Old Apr 28, 2013 | 08:24 AM
jafir's Avatar
Front fog lights will require the switch, the relay, the fuses if not already there, and someone to reprogram the BCU to know they are there. All of the wiring is already present as you've noticed. And of course you'll need the fog lights and whatever trim on the bumper, depending on the year of the D2.
Old Apr 28, 2013 | 10:27 PM
Tomzsix's Avatar
Why would the company put in a rear fog switch and not a front fog switch?? I have a 2002 SD, how cheap is that??
Old Apr 28, 2013 | 11:00 PM
jafir's Avatar
Because the rear lights are standard.
DiscoBeau
Dec 28, 2013 12:22 PM
ZGPhoto
May 2, 2013 11:40 AM
hobiecat
Aug 3, 2007 08:33 AM
97DISCOIDAHO
Aug 30, 2006 02:40 AM
LordOphidian
Jul 20, 2006 06:29 PM
