Daytime running lights and the interior fuse panel
Old Dec 8, 2020 | 08:43 PM
sodaparis's Avatar
Default Daytime running lights and the interior fuse panel
Okay, any help/experience is much appreciated. 2002 discovery SE. I’m wanting to have DRL and have tried enabling them with nanocom. The settings give 3 options, drl off, drl with the small bulb in the headlight, or headlights on all the time.
I have tried setting both options and they do turn on correctly for each option but they rapidly flicker and the interior fuse panel sounds like an old 8mm projector, rapid clicking.
Researching other threads, it is said that the DRL is run through relay 5 and 6 (interior fuse panel)
My panel doesn’t have a 5 or 6. I see that in the 03-04 vehicles it does exist. Is there an outside relay that I need to look for on a pre-facelift vehicle?
one other thing I tried in the nanocom, body outputs I think, I selected DRL “on” and the headlights turned on with no clicking, key position 2 not running. But I assume this is just for testing vehicle components.
My 02 panel looks like this, no 5 or 6
O3-04 panel, with a relay 5 and a jumper where 6 would go.
Old Dec 8, 2020 | 09:36 PM
mln01's Avatar
Check out this thread. Especially post number 33.
https://landroverforums.com/forum/di...g-lights-59225
Search is your friend.
Old Dec 8, 2020 | 09:52 PM
sodaparis's Avatar
thanks so much for the direction, exactly what I
need.
Im pretty great at google searches, but I’m equally bad on the forum searches.
thanks again!
Old Dec 9, 2020 | 12:26 AM
nashvegas's Avatar
Just did this on my 00...
Per the TSB for 99-02:
1) add the metal resistor thing behind drivers headlight and remove the jumper/plug it in
2) Nanocom code DRL on
3) It should work
If you do not do #1 you get the rapid clicking in the pass fusebox
Old Dec 9, 2020 | 07:31 AM
mollusc's Avatar
need.
thanks again!
If you used "DRL" in your search terms, you should have received the following message at the top of your results:
The following words are either very common, too long, or too short and were not included in your search: drl
Meaning that you have to be a little more creative in your research.
G150driver
Nov 27, 2013 11:38 AM
rrrrralph
May 5, 2013 01:02 AM
CodyCasteel
Mar 31, 2013 09:41 AM
tedw
Nov 13, 2012 10:09 AM
ScottinNJ
Jul 11, 2007 08:14 AM
