Sponsored by: CARiD
simple electrical problem
Old Mar 28, 2013 | 03:00 PM
CodyCasteel's Avatar
Default simple electrical problem
can you help me? i accidentally grounded the aux power on my trailer wiring and i blew a fuse/relay. looked at all my fuses under driver console,cant find it anywhere. i looked under my driver seat and found four fuses and two relays. im thinking its one of the two relays since every fuse on Ariel is good. and if it is a relay, is it something i can pick up at napa or will i need to go to a dealership? thank you
Old Mar 28, 2013 | 07:17 PM
F6 satellite fuse panel 2
F2 and F8 and F9 in main section of fuse panel under dash
F1 and F4 in main section of fuse panel under dash
F14 in main section of fuse panel under dash
Underhood fuse box has "bolt in" fuse links, which feed more fuses down stream. Check those as well.
Rear fog relay, and multifunctiuon unit on back of fuse panel might also be involved.
Old Mar 31, 2013 | 09:41 AM
Thanks Savannah, It was number twelve on series 1 the trailer fuse. The reason I didn't see it the first time was because it blew on the side as opposed to blowing in the middle/top.
Fallstaff
Mar 9, 2015 03:50 PM
mrossipir
Jun 22, 2009 07:59 PM
Mark G
Mar 19, 2008 05:28 AM
chelo
Oct 12, 2005 12:21 AM
Lebowski87
Aug 11, 2005 02:10 PM
