Dead battery again
Old Feb 13, 2008 | 09:24 PM
Disco2Guy's Avatar
Default Dead battery again
This first happened over Christmas break. I was out of town for 10 days and when I came back my battery was dead. Just now, I was going to go over to a friends house and the battery is dead again. It has been 10 days since driving it. I was in Utah Fri.- Sun., and when I came home I checked RovrFlo to make sure it was ok (just a visual check). I saw my alarm light was still flashing so I went upstairs. The PO replaced the battery (a DieHard) on 11/21/06 at 73,442 miles. My friend is on the way over now to give me a jump, and he has a multimeter. Where should I start looking for a possible cause?
Thanx
Old Feb 14, 2008 | 07:40 AM
StevenDiscoII's Avatar
Default RE: Dead battery again
I would start with the battery. Die Hard, made in Mexico now, aren't what they used to be.
Old Feb 14, 2008 | 08:00 AM
Die Hards are by far the worst big name battery on the market, all have been.
As for your problem, get it started and go back to sears, this is a joke, cause half the time they can't figure out how to open the hood much less do a battery and load test, but any way go have them test it.
Old Feb 14, 2008 | 09:20 AM
jkid's Avatar
Did you do any tests with the multimeter? That should give you a good indication if the battery is okay or if the alternator is working. The batteryshould reallybe charged up firstbefore a load test is done. It sounds like something is drawing off the battery when the truck is sitting. That can be common with some alarm/security systems. I don't know if it applies here though.
Old Feb 14, 2008 | 12:18 PM
Disco2Guy's Avatar
Didn't get to do a multimeter test yet. I have plans to get an Optima Red Top, but it might be sooner than I thought. It looks like there are a few different options, which one is best for the D2? I'll take it to Sears, but I'm not holding my breath.
Old Feb 18, 2008 | 06:06 PM
jairocol's Avatar
Hi , I am having similar problem with my discovery 96 where my battery is dying while driving because my alternador is not working correctly. Replaced Battery few tomes with a battery from Costco (100 monts warranty) and I also replaced Alternator ( when I took this one to autozone they say the diodes were bad), replaced battery and alternator and issue still there. ( only 12 volts when measure voltage thru both battery post. It is possible that I have a bad ground, your guys can give an idea where to look for.
Old Feb 18, 2008 | 06:54 PM
jkid's Avatar
First, with the engine running, check what voltage you are getting at the alternator itself, then follow that same (+) wire to the fuse box and take a look at the fusable link to see if it is intact. Check the voltage on either side of the fusible link just for kicks.
Old Feb 19, 2008 | 10:57 AM
D2G,
You can not charge a battery by driving it, unless you go a couple hundred miles or more.
You may have a good battery that just never gets charged enoung to stand the cold and down time.
Go get a full 2 hour charge, then have a load test run on the battery and alternator.
Your fellow club member,
MsCrystal
Apr 10, 2022 01:42 PM
abran
Jun 30, 2014 12:43 PM
mac55
Jun 16, 2012 05:00 PM
Dodger
Jun 22, 2011 09:19 AM
Dhwright
Jun 11, 2005 12:23 AM
