death shake
Old Jun 10, 2010 | 07:13 PM
aemnky606's Avatar
Default death shake
So i had/ have the death shake and i removed a few shims to fix the problem till the week end. Would this part fix the problem or is it bigger problem than this.
http://www.roversnorth.com/store/p-6...kit-upper.aspx
Walter
Old Jun 10, 2010 | 08:37 PM
greg409's Avatar
Is the top pin worn badly?
Is the thrust bearing bad?
Most often, just inspecting and re-shimming resolves the problem. (ASSuming it's mechanically sound)
When you removed shims, did you put a jack under the bottom until you re-torqued the top?
How'd you determine the preload?
luck,greg
Old Jun 10, 2010 | 08:38 PM
kenk's Avatar
The upper pin rarely gets worn, it's steel in a brass/bronze bushing. It's usually either the lower bearing or upper bushing
http://www.rovahfarm.com/DiscoIAxles.htm
scroll about halfway down
Old Jun 11, 2010 | 04:57 AM
aemnky606's Avatar
re-shimmed it about 2 months and it went away and it started back this week so i assume its time to replace some parts.
georgep
Jul 6, 2014 08:39 AM
jeffh
Jan 20, 2011 12:35 PM
614buxnut
May 18, 2006 03:24 PM
mcclellandm
Nov 26, 2005 04:54 PM
wax
Nov 20, 2004 05:32 PM
