Definitive guide to CDL transfer case swap?
Old Nov 2, 2019 | 08:26 AM
soarvet's Avatar
Default Definitive guide to CDL transfer case swap?
Hey all, have a 2002 Disco 2. I really want to do the cdl transfer case upgrade. I’ve been reading a bit, but have yet to find a definitive guide on how it’s done. From what I’ve gathered it seems pretty straight forward, just a matter of swapping the transfer cases. My question mainly revolves around the electrical. Lights on the dash etc... I know a lot of you have done it. Has anybody documented it?
Old Nov 2, 2019 | 12:31 PM
acg's Avatar
acg
Old Nov 2, 2019 | 12:42 PM
Jason Feuerstein's Avatar
For the dash lights, all you need is an 03/04 SLABS. No wiring required.
You are, however, going to have to make sure you've got the transfer case solenoid wired correctly. On the later models, the solenoid is on the shifter rather than the back of the transfer case.
Old Nov 2, 2019 | 01:31 PM
Best4x4's Avatar
Wiring for the solenoid is the same. Just bypass whichever solenoid you want (I prefer to use the 04 solenoid) but it’s easier to keep the setup you currently have.
Old Nov 3, 2019 | 10:11 AM
Brandon318's Avatar
A G R E E D. You mentioned me doing this earlier this year and now that I’m on the other side of the CDL installation, SO glad I did the ‘04 solenoid spot. I think the previous version is actually super idiotic. Well, maybe not idiotic. I see what they were doing. If the solenoid failed, it would plunge in the most probable, safest position since gravity would draw the rod downward. But what a cluster if you’re in low gear when it fails.
DailyDrivenTJ
Jan 25, 2017 02:02 PM
lr3_ovrlnd3r
Jul 20, 2016 08:22 PM
sdhow
Oct 16, 2014 06:31 AM
ralphobell
Jun 10, 2014 10:08 AM
pgoodrich
Jul 4, 2013 10:31 PM
