Desperate for help
Old Jul 24, 2015 | 10:18 AM
  #21
abran's Avatar
Where are you located? Maybe a member near you has a tool and can reset your system?
Old Jul 24, 2015 | 11:16 AM
  #22
Motorhead1's Avatar
[QUOTEThe shop said they charged the battery and the battery test showed up good. The weird part is that if you plug in the scanner, you will not get a connection, and that is what I haven't seen many people relate to this issue. ][/QUOTE]
I'm not real sure on a Rover, but I've seen a couple of American made cars with this issue, and both times it was a blown fuse. Usually on the same circuit as the cig lighter.
Old Jul 25, 2015 | 09:40 AM
  #23
sDot's Avatar
I am in the Toronto area in Canada.
Old Jul 25, 2015 | 09:42 AM
  #24
sDot's Avatar
I'm not real sure on a Rover, but I've seen a couple of American made cars with this issue, and both times it was a blown fuse. Usually on the same circuit as the cig lighter.[/QUOTE]
This mechanic has gone through all the fuses and so have I am not sure if having a bad cig lighter fuse would have all these issues. I can check, but if so, that is a very poorly built system. If you plug in your phone to charge and something shorts than you whole vehicle become inoperable.
Old Jul 25, 2015 | 09:44 AM
  #25
sDot's Avatar
You can't just swap in a used ECU, it has to be synced using Land Rover specific tool.
Or, you need to change the ECU, BECM, and gauge cluster as a set.
I was hoping that if I put in a new ECU it would either start or show some condition that will either prove or disprove the fact that there is an issue with the old ECU.
Old Jul 25, 2015 | 09:49 AM
  #26
sDot's Avatar
I could probably make a killing stripping the truck as everything is pretty much new.
It's cranking like a charm, but no spark, doesn't turn over, no ecu connection, M & S Lights and flashing D, and we have been through the wiring and fuses over and over.
I keep running back to the shop to check each suggestion here, and I think they are sick of me by now running back in a recheck a fuse that was check by a bunch of different people.
I wonder if anyone local needs a new truck that only needs to figure which fuse is bad.
Old Jul 25, 2015 | 11:29 AM
  #27
RoverMasterTech's Avatar
Ill give ya 3.50 for it
Old Jul 25, 2015 | 03:32 PM
  #28
sDot's Avatar
Actually, if I can get it started I may drive it off a cliff and see how much money I can bring in with a viral youtube video.
Or if I charge 35 guys $100 each to use it as a shooting target for sniper training, I will come out ahead, and everyone will have fun.
Old Jul 25, 2015 | 03:36 PM
  #29
sDot's Avatar
In the event that this "new" ECU works, what do I have to do through to get it working.
Will the truck at least start?
Old Jul 25, 2015 | 03:42 PM
  #30
GROVERDISCO's Avatar
Have you swaped out the crank position sensor? Might be worth a shot.
Good luck.
