detecting crank sensor fault
Old Jun 16, 2008 | 02:47 PM
Roveroh's Avatar
Default detecting crank sensor fault
Can Rovacom or similar diagnostics detect a crank sensor failure? I'm getting no OBD II codes. I replaced my malfunctioning AC condensor fan, but I my research here tells me this could be my "crank but no start when warm" culprit.
Old Jun 16, 2008 | 06:15 PM
Default RE: detecting crank sensor fault
Usually is and quite often it will not throw a fault.
Check and see if you have any spark when it won't start, if not, it is the crank sensor.
Old Jun 16, 2008 | 07:14 PM
lrobin3w's Avatar
I am not familliar with the rovacom, the factory diag tool has a "no start" test, which starts with a reluctor ring tooth count as measred by the ckps. If this count does not increase when cranking the sensor is bad.
Old Jun 17, 2008 | 06:53 AM
Roveroh's Avatar
Thanks all-
How much should I expect to be charged by a LR mechanic (not a dealer) to replace it?
Old Jun 17, 2008 | 07:52 AM
$88 for the sensor and an hours labor.
Old Jun 17, 2008 | 09:30 PM
roverguy7's Avatar
dont forget the hour and a half diag... if not, and its not the right repair, as in it might only be an immboilization resync, you will be responsible for any further diag as to why its not fixed...
Old Jun 18, 2008 | 08:33 AM
Roveroh's Avatar
I had it scheduled for a diagnostic anyway due to a tranny fault I received. I did an OBD II scan myself and came-up with nothing, not that my check engine light came on.
06Range
May 8, 2013 09:01 PM
cgeschwell
Feb 23, 2011 01:01 PM
stupid
Nov 23, 2008 01:17 PM
Roveroh
Jun 13, 2008 07:14 PM
