Developed a New Leak
Old Apr 27, 2025 | 04:45 PM
alw85's Avatar
Default Developed a New Leak
Took my 2000 Disco out a few weeks ago and since then I've had a leak between the engine and the transmission. Wondering if it's just the rear seal or should I do a pull the engine and verify everything.
Old Apr 27, 2025 | 05:28 PM
Extinct's Avatar
Almost never the rear main (explanation here: https://landroverforums.com/forum/di...e2/#post711847), could be crucifix seals which can be replaced by dropping the pan, or could be the rear cam plug (assuming it is engine oil leak) which require trans or engine come out or it could be leaking from heads or valve covers or lower intake.
Old Apr 27, 2025 | 06:29 PM
Brandon318's Avatar
When I thought my rear main seal was leaking, it was actually either the head gasket, valve cover gasket, or intake manifold gasket. Replaced all three at once so not entirely certain which it was but it's now dry as a bone. Point being, it's most likely coming from somewhere up top and finding its way down to mimic the appearance of a RMS leak.
suntreemcanic
Nov 10, 2021 02:04 PM
cvhyatt
May 13, 2020 05:31 AM
Greenhead
Jun 24, 2014 08:48 PM
thehun
Nov 19, 2010 10:22 AM
newdr
Nov 18, 2008 09:04 AM
