REAR MAIN LEAK
Old Nov 17, 2008 | 11:41 AM
newdr's Avatar
Default REAR MAIN LEAK
LOCAL MECH IS CHECKING AN OIL LEAK WICH IS PROVING DIIFICULT TO PIN DOWN.
MAY BE A REAR MAIN LEAK? IF THIS IS THE PROBLEM HOW MUCH SHOULD IT BE TO FIX?
DISCO 2003, 96K
Old Nov 17, 2008 | 11:49 AM
discoxd's Avatar
Default Re: Rear main leak
your disco is just leavin you a trail so you can always find your way home...
________
Colorado Medical Marijuana
Old Nov 17, 2008 | 11:50 AM
Default RE: REAR MAIN LEAK
Well the part is like $.50, the rest is labor. They have to remove the transmission from the truck.
Old Nov 17, 2008 | 01:58 PM
newdr's Avatar
DIFFICULT TRAIL TO FOLLOW. I SEE ONE SPOT OVERNIGHT 1/4 INCH IN DIAMETER.
SWITCHED TO FULL SYNTHETIC 6 K AGO.
Old Nov 17, 2008 | 02:14 PM
There are a few things that will leak oil and look like a rear main seal, either valve cover, the head gaskets, the vally pan gasket and the rear main.
I wouls suggest you power scrub your engine so you can see what is leaking before you jump into a major repair.
Old Nov 17, 2008 | 03:02 PM
That leak is so small I wouldnt worry about it right now.
Wait until it leaves a big stain in the driveway.
Old Nov 17, 2008 | 03:29 PM
ORIGINAL: newdr
6K ago, it is time to change it again and go do waht I suggested on an earlier post.
Old Nov 17, 2008 | 03:37 PM
newdr's Avatar
I PLAN TO CHANGE EVERY 5 K. 1K AGO WHEN THE LAST CHANGE WAS MADE, THE MECH. NOTED THE LEAK.
MIKE, I AM NOT SURE OF WHICH POST YOU ARE REFERENG.
Old Nov 17, 2008 | 07:44 PM
discoxd's Avatar
i think he was talking about power scrubbing the engine and stuff to be able to see for sure where the leak is comin from... which is a really good idea... a couple weeks ago i though my front crankshaft seal was leakin really bad... well after cleanin the engine to the best of my ability i discovered it was my oil pressure switch leaking instead, so u may be happily surprised to find that the leak is really nothing... but you will never know for sure with a decade of road grime all over your engine...
________
Medical Marijuana Dispensary
Old Nov 18, 2008 | 09:04 AM
"YUP".
discoboy
Sep 15, 2011 12:00 AM
thehun
Nov 19, 2010 10:22 AM
Classklown90
Aug 22, 2010 04:26 PM
kae
Feb 23, 2010 08:37 AM
Belaou
Sep 11, 2007 07:43 AM
