DI DII interchangeable parts list
Old Aug 26, 2012 | 12:12 AM
Rover De Land's Avatar
Default DI DII interchangeable parts list
Forgive me if there is one of these already, I searched and found very few actual answers and non of it organized.
If you know of any please mention and I'll add to the list.
ENGINE:
Camshaft bearing set
Water Pump
Valve cover gaskets
Head bolt
Cylinder heads
Starter
Spark plugs??????
Lifters
Oil pump
Rocker shaft
Valley Gasket
Front cover gasket
Head gasket
Exhaust gasket manifold
Oil seperator
Push rod
Rod bearing
Piston assembly (up to 02)
Piston ring
Timing chain
Rocker arm
Camshaft (up to 02)
Freeze plug
Most engine oil seals
Flywheel
Flex plate
Valve cover screws
Oil cap
Valley gasket end clamp
Fan/water pump pully
Valves
Valve guide
Exhaust manifold bolt spacer
Exhaust manifold nuts
Valve spring
Oil pressure switch
Cruise control actuator
Inertia switch
Transfer case oil temperature switch
Interior:
Switches for fogs and such
Brake boot
Transfer case boot
Window and heated seat switches
Turn signal/headlight switch/arm
Clock spring/coil Spiral cassette
Sunroof control unit
Sunroof motor
Sunroof
Mirror motor switch
Window regulator
Window motor
Center console ?
Center consol lid latch
Glove box latch
Drivetrain:
Transmission (up to 02)?
Transfer case and CDL
Transmission Filter
Exterior
Wiper arms
Rear wiper motor
Rear cargo door handle
Mirror glass
Door seals
Back door hinge
Headlamps [up to 03]
More to come
Old Aug 26, 2012 | 08:13 AM
Head light assembly from early D2s, they do have a black rim around the silvered area, where the D1 is silvered to the edge. But they fit, and I have one of each, make's it look like it has come out of the woods with a black eye, soulda seen what the Hummer looked like....
Old Aug 26, 2012 | 09:05 AM
ZGPhoto's Avatar
There is a difference between earlier DIs and later DIIs, so your list isn't entirely correct. The head bolts are not the same with earlier DIs and DIIs.
Rachel Ojani
Mar 18, 2014 08:43 AM
dr. mordo
Jun 10, 2013 08:09 AM
cipher982
Jul 18, 2011 07:55 PM
yloDiscoII
Feb 24, 2010 10:37 AM
Suede
Oct 4, 2009 01:19 AM
