DI Tranny Filter without removing y-pipe? Who has done it
I read recently that you could pull the tranny pan on a DI without the need to remove the y-pipe. As I recall, the poster pulled the nuts and bolts on the crossmember and moved ti forward (it doesn't look like moving it back will provide any more access). The pan could then be manuevered out and the filter was then accessible. I have searched and searched but havent' been able to find the post. I looked last night and it looks like there is only about 1 inch between the crossmember and the cats. If I removed the nuts and bolts of the crossmember and knocked it forward an inch, is that enough to get the tranny pan out? Things look very tightly meshed in and around the tranny pan. Any help would be greatly appreciated. Thanks Phil
1999 DI 105k miles, inoperable tranmission, I am hoping it is a clogged filter......
Mike, this is the truck that has the transmission that is not engaging. I can move the shifter into r, d, 3, 2 or 1 and nothing happens. Checking the dip stick, it appears that it is several quarts overfilled (eventhough the fluid level is accurate). I am thinking that either the pump has failed and thus the fluid is not being pumped to the upper portions of the transmission or the filter is clogged and the fluid in not passing through the filter to the pump. I thought that I would pull the filter and take a look before I swapped the transmission for a used one. The fluid is clean and clear, unburnt and changed about 3000 miles ago. Phil
1999 DI 105k miles
1999 DI 105k miles
Spencerfitch, normally I would agree wholeheartedly and I may end up having to do that. I have limited time and if it needs a new tranny, I will have a shop do that rather than try it myself. I have three different options, 1. tranny with 118k installed for $600, 60-day warranty; 2. tranny with 78k miles installed for $950, 90-day warranty 3. tranny with 95k miles no warranty $1400 (from well respected Rover shop, the other two are by experienced but non-rover specific shops). I am leaning towards option 2 because of the miles on the tranny. Hopefully, all it needs is a new filter.........I put the odds at less than 25% that a filter will fix the problem. Phil
me 2
06-21-2016 08:28 PM
928paul
03-04-2016 05:26 AM
s10lowrider1994
01-16-2012 07:08 AM
audiS4S6
04-30-2010 09:40 PM
