Diamond plated roof rack floor :) pics inside
Old Jan 24, 2010 | 12:34 AM
tweakrover's Avatar
if you cut different size holes in the right spots you might get it to play a tune as the wind blows through it. but seriuosly don't cut holes in good diamond plate, you could use it on another project. Give the rack a try while you come to terms with the idea that you may have made a mistake in you plans along the way. But I do appreciate your "do it myself" attitude, good luck.
Old Jan 24, 2010 | 07:33 AM
VFib-911's Avatar
Not to jump onto the "don't use it as it is" bandwagon, but lift may not be your only problem. Most Disco's I have seen are slightly nose-heavy, this would result in significant down-force, eventual overload and failure of the gutter mounting rails, and then loss of control of the piece.
Awesome job on putting that thing together from scratch, but please heavily reconsider your choice of flooring - both for your safety as well as others on the road.
Best regards,
Old Jan 24, 2010 | 05:29 PM
poorway09's Avatar
4wd High
Default Diamond plated roof rack floor pics inside
Good pics looks like its coming along very nicely, There are a few getting around down here that are look prety well kitted too.Are snorkels available for the Hummers?Rich
Old Jan 24, 2010 | 08:49 PM
rj95lss's Avatar
I can't wait to see this thing mounted. I would certainly cut some holes in it though, it will make it easier to strap stuff down too.
Good Job and Good Luck-
Old Jan 25, 2010 | 12:48 PM
yloDiscoII's Avatar
Looks good, can't wait to see that beast mounted up!
You can even use it as a giant skillet in the summertime!
Old Jan 25, 2010 | 12:59 PM
rj95lss's Avatar
If you do decide to remove that plating you can pickup 2 sheets of this for $40 - http://www.farmtek.com/farm/supplies...roductId=20251.
Several guys on here have used this stuff and I think there is even a right up on where to cut it and how to secure it.
Old Jan 25, 2010 | 01:44 PM
hilltoppersx's Avatar
that is what our club reccomends as well. the chicken coop flooring from farmtek
Old Jan 25, 2010 | 01:53 PM
rj95lss's Avatar
Is that stuff sturdy enough to walk around on it? Does it help cut down on the noise/whistling from the rack or add to it?
Old Jan 25, 2010 | 02:00 PM
rj95lss's Avatar
Has anyone used RhinoRAC flooring - http://www.offroadtuff.com/DiscoIILRN50120.htm - ?
OR
The King XL-Lite flooring - http://www.roverracks.com/king_xl.htm - ?
Old Jan 25, 2010 | 03:23 PM
yes it is sturdy enough to walk and load on. overlapping works best. If your concerned about noise i would suggest no rack at all or a deflector on the front of the rack. I don't think the coop flooring adds any noise IMO.
