Did I cause this?
Old Dec 16, 2009 | 11:25 AM
outback96's Avatar
Default Did I cause this?
I am wondering if I caused this problem? A couple of tanks ago, I put reg. 87 in (needed gas asap; couldn't fine a station with 93) Well, since everything seemed to be ok, no immediate CEL or bad starting, nothing ran just as smooth as with 93 gas. I put a few more tanks of the reg. 87 in. Now, after switching back to 93, I have a few codes poping up.
the codes are: P0154 (o2 pass. #1) P1300 (fuel sys. or miss fire) P0308 and P0302 (miss-fires in #2/8 cyl. So, I'm wondering if running the 87 gas has caused this problem or is this just something that has happened...
thanks again.
Old Dec 16, 2009 | 11:43 AM
And you had to ask????????????????????????
How many miles on your truck and has it ever been tune along with wires?
You are easily loosing 2 MPH plus a huge amount of low end torque, much lee carboning up your engine.
Old Dec 16, 2009 | 12:14 PM
outback96's Avatar
The truck is a 2000 with 136k and I believe at 132k land rover of greenville, sc. did a tune up on her.
Old Dec 16, 2009 | 12:40 PM
outback96's Avatar
I miss spoke; truck did not have tune up @ 132k. unknown when was done last.
Old Dec 16, 2009 | 12:54 PM
hilltoppersx's Avatar
see mikes 60k service in the HOW TO section and use 93 or 91 gas from now on.
Old Dec 16, 2009 | 02:22 PM
lipadj46's Avatar
I'm not sure if just a few tanks of regular would give you misfires and kill an O2 sensor. When you had the tuneup did they do the wires?
Old Dec 17, 2009 | 06:19 PM
apcollin's Avatar
I doubt the low-octane gas was the only thing responsible... there are so many Disco's running around with people driving them who don't know the need 90 or better...
definitely could have been a contributing factor but i'd look to your plugs and wires first
Old Dec 17, 2009 | 07:57 PM
he just needs a tune up, and most likely wires and plugs.
Old Dec 17, 2009 | 09:33 PM
brianb883's Avatar
thanks again.
Its likely that you just have some carbon buildup somewhere in your engine, try running a can of seafoam in the gas tank, as well as through the induction.
Evian
May 3, 2008 05:10 PM
Testpilotb
Dec 18, 2007 08:58 AM
ajh
Oct 4, 2007 09:59 AM
CPDieker
Aug 8, 2007 08:13 AM
