Died on Highway, sounds like CPS with a twist
Old Jan 25, 2022 | 04:26 PM
  #51
wjsj69's Avatar
You just want to see all the rockers moving equally while cranking the engine. If not there's a cam or chain problem (or bent push rods but that would be obvious). But now, hearing that the wiring issue was found at the time of failure, it's more likely to be the problem. The confusing thing is that you have low compression too. I don't think the engine would keep running long enough to do internal damage once the ECU failed. Unless you had bad enough luck to have electrical and mechanical failures at the same time. I'm officially confused. I would try an ECU first. With the disclaimer that I don't know which wires you are talking about, exactly, and it could be anything related in any way to the damaged wires, not just the ECU, or the ECU at all..
Old Jan 26, 2022 | 12:20 AM
  #52
JohnZo's Avatar
Default I meant timing chain not timing
Here's a simple way to do some minimal checks of the ECU with key on engine off, with live data from your OBD scanner. Check throttle position, it should follow as you press the gas pedal. Check engine coolant, fuel rail, and intake air temperatures, they should be at room temperature. Look at MAF and O2 sensor voltages to make sure you are getting some readings (I forget if O2 voltage is high or low, but it's one or the other). There might be other things you could check to see if values are normal. If everything looks reasonable, the ECU is probably OK, and vice versa.
On the mechanical front, if you get good cylinder pressure after adding a spoonful of oil, then rods and valves and timing chain and cam are all OK. The oil simply helps the piston rings seal better.
Old Aug 11, 2023 | 08:59 PM
  #53
I Brake For Cats's Avatar
Hello all, after a long hiatus I finally got back to tinkering on the Rover this weekend.
CONCLUSION: The bolt holding the cam sprocket had backed out almost entirely. The sprocket was not being held in, and the bolt was about 3 full turns (by hand, no tools needed) from coming out completely and the timing chain slipped off into my hand before removing it fully.
I wonder if anybody has experienced this before. I'm guessing with my limited knowledge that the bolt loosened incidentally, and the timing chain jumped as a result? The chain and gears all look fine but I will be replacing them shortly as I put this back together.
If this sounds wrong please correct me!
ClutchMcGillicuddy
Mar 4, 2016 03:42 PM
GregL
Jan 10, 2015 06:28 PM
gschmitt
Dec 14, 2014 05:06 PM
gpelite
Sep 19, 2014 07:37 PM
jkid
Jul 18, 2009 09:23 PM
