diesel rover braking system question
Old Mar 3, 2010 | 02:53 PM
NiteTrain's Avatar
Default diesel rover braking system question
how do they boost the brakes on the diesels? Do they use some kind of hydroboost system like a GM diesel or a power steering/braking pump like a bmw?
Old Mar 3, 2010 | 04:44 PM
Engine vacuum just like a gas engine I would assume.
Brakes is brakes man.
Now if your talking air brakes thats a whole other story, but I assume you are talking Rover brakes.
Old Mar 3, 2010 | 05:00 PM
lipadj46's Avatar
I believe the braking system is the same as in the gas engines but there is a vacuum pump for the brake booster line instead of using the vacuum pull off the plenum in the gas engine.
Old Mar 3, 2010 | 07:28 PM
antichrist's Avatar
Diesels don't have much vacuum.
Different diesels use different methods.
My Perkins has a vacuum pump driven by the timming gears.
My Rover 2.25 has a dodgy flapper valve thing in the inlet manifold so what little vacuum is created isn't lost.
My 300Tdi has an engine driven pump
Old Mar 3, 2010 | 08:14 PM
NiteTrain's Avatar
yeah, like antichrist said diesels don't have enough vacuum for boost that's why I was asking. Thanks for the info anti.
Old Mar 3, 2010 | 08:25 PM
I learned something.
When I drove truck they all had airbrakes so I never thought about it.
As long as you had PSI you could stop.
If you lost PSI your brakes locked up, pretty simple.
Old Mar 4, 2010 | 06:22 PM
Urban Panzer's Avatar
The Diesel D2 is no different,
My TD5 has a vacum pump connected / drive off the alternator for brake assistance
roverdisco1017
May 5, 2021 09:56 AM
tbarton
Jul 6, 2013 02:39 PM
salve7
Sep 30, 2009 07:40 PM
Weiner769
Aug 31, 2008 09:19 AM
NiteTrain
Aug 29, 2008 08:23 PM
