diff oil... did I mess up?
Old Aug 3, 2015 | 08:26 AM
Charlie_V's Avatar
Default diff oil... did I mess up?
Changing my ball joints I lost a lot of diff oil from the axle tube and all I can say is that I wasn't thinking clearly. Exhausted, sunburned, hot... I grabbed the "only" gear oil I saw in the garage thinking that must be the one, laid on the concrete, and pumped it full of 85w140. Later, when I was putting things up, I found a cache of 70w90.
I live in Texas so it is real hot right now. I searched the forums and it seems either will do but most of my driving is highway and I have 150,000 on my truck. No idea whether I mixed oils.
Did I mess up? I cannot recall which oil is in the diffs and transfer case. I have a few cars/trucks so maybe the 85w140 was for something else.
Old Aug 3, 2015 | 08:32 AM
Alex_M's Avatar
Nah, I have 85w140 in mine. It's just heavier than factory and better for more heavy duty uses, but won't cause you any problems.
Old Aug 3, 2015 | 08:36 AM
Charlie_V's Avatar
Eases my mind. Thanks, Alex. I'm probably due for a complete drain and fill this winter anyway... would you stick with the 85 or go down to a 70?
Old Aug 3, 2015 | 09:02 AM
Stay with the heavier oil be it synthetic or not, the gears will wear less and cooler.
Old Aug 3, 2015 | 09:12 AM
antichrist's Avatar
The Rover diffs in Series Land Rovers, which are exactly the same design as Discovery diffs, spec'd 90w.
You're fine, I've been running 85w140 for 40 years, from Georgia summers to northern Vermont winters.
lipadj46
Sep 11, 2010 07:49 PM
bdiseati
Freelander
Jul 22, 2010 09:14 PM
Buzz09
May 12, 2010 03:01 PM
grussell
Jun 26, 2009 05:59 PM
mattrickman
Jan 11, 2009 08:39 PM
