Differential lock warning lamp
Electrical in the Rave download with large file warning.
Some of the DTC codes we may encounter are not in Rave and may not be applicable to our vehicles. Are getting an engine light? Can your clear them and do the return? I usually do a web search for code adding Rover to it. https://www.google.com/search?q=J2012&ie=utf-8&oe=utf-8
Fixed!!
Ok, I was afraid of that. You shorted something out. You need to go back and find out where you shorted the brakes with your trailer wiring when you tried to hook it up.
You didnt know this I'm sure, but they make a "plug-N-play" trailerwiring kit, you plug it into the wiring harness on the truck and you are good to go.
You need to find out what you did wrong.
DiscoRover007
08-26-2012 10:48 AM
calbuild
09-14-2009 11:08 AM
