Differential lock warning lamp
Old Jul 6, 2016 | 08:24 PM
Broken08's Avatar
What was the culprit?! Same problem
Old Jul 6, 2016 | 09:01 PM
disc oh no's Avatar
Did you just install trailer wiring, like in the original post?
Old Jul 6, 2016 | 10:19 PM
Broken08's Avatar
Nope, but I took out the module from my tail lights to rule it out, but it keeps blowing the tail light fuse.
Old Jul 7, 2016 | 05:55 PM
disc oh no's Avatar
If it keeps blowing the fuse something is shorted. You'll probably have to go over the wiring for the brake lights very carefully. These things can be hard to find sometimes.
Old Jul 11, 2016 | 01:40 PM
Broken08's Avatar
is there a wiring diagram in the RAVE? Just not sure how to trace them without it
Old Jul 12, 2016 | 06:38 AM
number9's Avatar
Old Dec 13, 2016 | 10:04 PM
organic.chemist's Avatar
Default Fixed!!
Originally Posted by Spike555
Ok, I was afraid of that. You shorted something out. You need to go back and find out where you shorted the brakes with your trailer wiring when you tried to hook it up.
You didnt know this I'm sure, but they make a "plug-N-play" trailerwiring kit, you plug it into the wiring harness on the truck and you are good to go.
You need to find out what you did wrong.
I saw the same problem today (diff light was on, goes off when I press the brake, and can't get out of park . . . also no brake lights). Having replaced the brake switch recently I jumped to the assumption that I had gotten a lemon, and bought another one, but that did not fix the problem. Realized that it must have been a short, and tracked it down to a trailer wire that had been pinched when I was unhitching it earlier this morning. Fuse #25 was blown. Patched the trailer wire, replaced the fuse, and I'm rolling!
Old Dec 14, 2016 | 05:01 PM
Broken08's Avatar
mine was a short in the transfer case wire and/or a short in a wire to a reverse light. I found both and fixed them.
jfall
Oct 5, 2013 11:19 AM
Peter Van Slyke
Sep 3, 2013 07:39 AM
DiscoRover007
Aug 26, 2012 10:48 AM
bothomasmusic
Apr 24, 2011 09:25 AM
