Differential woes.
The p38 and "wolf" military diffs are different. Both are four pin but they arent interchangeable.
And I think the p38's only had the 4 pin if they had the 4.6? Or maybe they only had it in the rear diff? Either way, if it is a four pin, it's either wolf or a short nose p38 and neither are a direct swap for your stock long nose.
Can you swap an entire front/rear axle (which obviously includes the diff) between Disco 2 and P38 or Wolf in order to get OEM 4-pin, then??
Nope, would cost more in fab work that you would spend on an aftermarket carrier. I suppose you could buy one of megasquirts modified p38 units, but I bet they are $500, just as much as an aftermarket LSD.
So just buy an aftermarket carrier...
