Difficult SAI issue - Throwing codes P1412 & P1415
Old 04-08-2023, 10:28 AM
mackendw's Avatar
[@tparsons] can you send a pic of the rubber hose that you adjusted with the elbow and to which canister you are referring to? mucho gracious.
  #22
Old 12-06-2023, 11:45 AM
mackendw's Avatar
I realize this is an older thread...I'm troubleshooting the P1412 and P1415 codes after putting a new (ebay) SAI pump on. Are you supposed to be able to blow thru the air reservoir in both directions...ie: should there be any restrictions? I pulled the hose on one end that connect to it (straight hose to nipple connection) and can blow thru that rubber line fine. but on the other end, when i pulled the rubber elbow off, I could not blow thru that end...
  #23
Old 12-06-2023, 06:33 PM
Extinct's Avatar
Received 1,503 Likes on 1,066 Posts
There are no check valves in that line.
  #24
Old 12-06-2023, 06:49 PM
mackendw's Avatar
that line connects to the SAI solenoid so that is normal then?...ie: until the valve opens you wouldn't be able to push air thru...right?
  #25
Old 12-06-2023, 06:56 PM
Extinct's Avatar
All the lines should be open when disconnected. Not sure what you are asking. You can test the valve with a jumper across the terminals.
discoinfernoOSV
01-09-2022 09:58 AM
dgm
08-08-2018 12:48 PM
tparsons
07-28-2014 12:53 PM
DIIZ
07-16-2013 08:14 AM
brianb883
02-03-2011 06:34 PM
Quick Reply: Difficult SAI issue - Throwing codes P1412 & P1415
