Difficult SAI issue - Throwing codes P1412 & P1415
Old Apr 8, 2023 | 10:28 AM
  #21
mackendw's Avatar
[@tparsons] can you send a pic of the rubber hose that you adjusted with the elbow and to which canister you are referring to? mucho gracious.
Old Dec 6, 2023 | 11:45 AM
  #22
mackendw's Avatar
I realize this is an older thread...I'm troubleshooting the P1412 and P1415 codes after putting a new (ebay) SAI pump on. Are you supposed to be able to blow thru the air reservoir in both directions...ie: should there be any restrictions? I pulled the hose on one end that connect to it (straight hose to nipple connection) and can blow thru that rubber line fine. but on the other end, when i pulled the rubber elbow off, I could not blow thru that end...
Old Dec 6, 2023 | 06:33 PM
  #23
Extinct's Avatar
There are no check valves in that line.
Old Dec 6, 2023 | 06:49 PM
  #24
mackendw's Avatar
that line connects to the SAI solenoid so that is normal then?...ie: until the valve opens you wouldn't be able to push air thru...right?
Old Dec 6, 2023 | 06:56 PM
  #25
Extinct's Avatar
All the lines should be open when disconnected. Not sure what you are asking. You can test the valve with a jumper across the terminals.
discoinfernoOSV
Jan 9, 2022 09:58 AM
dgm
Aug 8, 2018 12:48 PM
tparsons
Jul 28, 2014 12:53 PM
DIIZ
Jul 16, 2013 08:14 AM
brianb883
Feb 3, 2011 06:34 PM
